Survey123 submitted data from mobile devices are not uploaded to AGOL
2023
5
07-05-2018 11:07 AM
by Anonymous User
Not applicable
In Survey123, I have created a simple survey through the web interface. Link: https://arcg.is/1Kme1n - I have not changed fields since publication.
When the submitter use the Survey123 app for iOS or Android, their submissions including position, filled in information and photo are apparently transferred via WiFi  to the server according to the apps.
However, nothing shows up in the Data tab, so ArcGIS Online and Survey123 haven't received anything
Settings in the Collaborate tab:
In the Survey123 app for Android (downloaded yesterday, so recent version)
Results in the Data tab on the Survey123 website:
Results in AGOL:
JamesTedrick
Esri Esteemed Contributor
Hi Karl,
Can you please check the settings of the _fieldworker feature layer view in ArcGIS Online?  In particular, the 'What features can editors edit?' setting must be set to 'Editors can edit all features' when a survey has an image question (even if the setting is disabled).  If the setting is disabled, temporarily change the 'What kind of editing is allowed' to 'Add and Update' to enable that setting, make the change, and then restore the 'What kind of editing is allowed' setting.
JamesTedrick
Hi Karl,
by Anonymous User
Not applicable
OK.
1) I go to AGOL, 2) find the feature layer [survey name]_fieldworker, 3) Press Settings tab, 4) Scroll down to "Feature Layer (hosted view), and change accordingly:
Then try make a new submission of observation
by Anonymous User
Not applicable
In the Survey123 app for Android, I do a registration and submit the answer including a photo.
In the [survey name]_fieldworker table at AGOL, I check for new records.
Yes, there is a new record from the recent app submission.
by Anonymous User
Not applicable
 Could this be changed in Survey123 website configuration parameters. It seems not straightforward to know that the user should go from one website to another to make this happen.
JamesTedrick
Hi Karl,
Yes, we plan to update the Survey123 website to enable making the appropriate settings from there in the future.
