Feature Class Extents Change
1008
07-05-2018 08:18 AM
JoeBorgione
I've seen this happen again and again,but cannot explain it :  at any given time, one can view a feature class in ArcCatalog and not see the features because the Extents have changed radically; typically in an eGDB.  How does that happen?  The fix is easy, just recalculate the extents, but knowing the cause of the problem and resolving that is a better fix.
Tags (1)
DanPatterson_Retired
The only time I have seen an extent change is after a geometry edit that I discarded.
