Point Feature Label Rotation
1915
06-26-2018 11:49 AM
BrianO_keefe
Honored Contributor
I have spent a good couple of hours trying to figure out why I can't get these labels to rotate on a web map.
I thought I had done this before.
I've set the labels on the MXD to rotate based on an ANGLE field in the point feature class. But nothing I do on the AGOL side shows those rotated labels. I can create an AGOL layer from the MapServer version, the FeatureServer version, I can adjust everything I know how to adjust and nothing makes those labels display rotated.
Are point feature labels unable to be rotated on an AGOL Web Map?
RobertScheitlin__GISP
Brain,
   I do not know of any ability to rotate label on a layer in an AGOL web map when choosing to create the label inside the web map.
DerrickWestoby1
I'm not publishing an entire map/MXD, but here's a screenshot of a hosted feature label with rotated symbols based on attributes in AGOL.
(Zipped SHP uploaded and published, changing symbol in AGOL)
