Add Data widget
1492
5
06-26-2018 07:41 AM
ahmedSalam1
Hi i am trying to configure the Add Data widget in My map portal using Zip. folder to Add all elements of Shp file but i got an error message (Generate Features exception 'null' ) do you have any solution on that
KellyGerrow
Esri Alum
Can you share the shapefile or get in contact with technical support
ahmedSalam1
i  tried to add many shp file with less 1000 features but still i got same error even i check the geometry every thing is fine with shp file
even when i try to Add it from add layer from file i got the same
how can i send it
ahmedSalam1
Hi Kelly,
thanks for following up, please find the attachment
Ahmed
KellyGerrow
Esri Alum
Hi Ahmed,
Is this an application that you created? The shapefile adds fine through ArcGIS Online Add layer from file workflow. adding Web AppBuilder for ArcGIS‌ for more insight.
ahmedSalam1
so what's wrong then in my setting
