Change layout of outbox/concepts
2002
06-26-2018 04:30 AM
Nielsvan_Rijn2
Is it possible to change the layout of the concepts and outbox page in survey123?
Our colleagues sometimes need to wait for more data before submitting a survey. While waiting for the data the survey is added to the concepts or outbox folder. The default page doesn't show much information about the different surveys (see example attached). Can the layout be changed by showing different fields and showing the first picture taken?
DeonLengton
Hi Niels
I think what you are trying to do is change the instance name of the records. You can do it by manipulating the instance name setting of the survey. Here is an article about it https://community.esri.com/groups/survey123/blog/2017/04/24/understanding-the-instancename-setting
Nielsvan_Rijn2
Thanks!
Is it also possible to show the first picture taken?
DeonLengton
No unfortunately not... unless you customize Survey123 with AppStudio
