Updating Feature Layer by geocoding an address, but for_storage = true gives error?
1449
06-21-2018 08:43 AM
DeepakBegrajka1
Hello All,
I have written a python script, which pulls down a layer of data from our portal, I have bunch of address which I geocode and add it to layer, while geocoding if don't use for_storage = true variable it works fine, add data display it correctly, but if I use for_storage = true which I am supposed to use as I am storing that geocoded result to my database, it gives me several different errors which are:
Error Code 403: which says the user does not have permission to store geocoding result?
But my user is an administrator, so it has all the possible permission, I also tried with publisher and editor it doesn't work.
Error Code 400: which says Invalid Username and password and Unable to generate a token
I am printing my token, and it is valid, as I have registered the script and using that client ID and Secret to generate a token, and I 100% sure the username and password are valid because as I remove "for_storage= true" from the
"results = geocode(i, for_storage= True)", it works.
Can anybody help me with it?
Deepak
chriseshleman1
I am receiving error code 403. Insufficient privileges to store geocode results. But I am an adminstrator. Did you solve this issue? If so, how?
Best,
Chris
