How do I capture geopoint queries as Lat,Lon values within a repeat?
697
06-13-2018 08:56 AM
MiguelParedes
I have a form for a survey with a repeat.  The repeat contains a geopoint query.  The geopoint within the repeat does not generate anything in the corresponding related table, which sort of makes sense.  Does the geopoint has a setting which allows it to capture the Lat, Lon values for the point instead of the geometry?  Or is there a way to best deal with this situation?
Miguel
JohnathanHasthorpe
Hi Miguel
I have attached an example survey that shows how to get the lat and long from the geopoint and write them to text questions.
I'm not sure what you mean when you say:
Could you share your survey?
John
