Enable SSL Failed
1548
06-11-2018 06:52 AM
MarkLittell
I have a new installation of 10.6 on machine A in it's own site.
I installed 10.6 on machine B.
When I try to join machine B to machine A's Site, I get a message stating:
Failed to join the site 'https://xxx.xxx.xxx.xxx:6443/arcgis/admin/' Enable SSL Failed.
I have confirmed on machine A, via admin/security/config that HTTP And HTTPS Protocols are enabled.
I get the same Enable SSL Failed message if I try to add machine B from machine A via Manager.
Thoughts?
George_Thompson
Esri Notable Contributor
Have you imported the certs into each of the server machines?
Configuring HTTPS using an existing certificate—ArcGIS Server Administration (Windows) | ArcGIS Ente...
--- George T.
MarkLittell
I have not, shouldn't need to, right?
These are two internal AGS systems and are in my Dev environment.
I am simply trying to get two AGS systems into one AGS Site.
On these same systems, (OS = Win 2016), I installed AGS before and was able to join them to the same site.
I then wanted to change the config store location, so I uninstalled AGS from each machine. I also deleted the arcgis server folders.
I then re installed AGS, and when trying to join the B machine to Site A, I get this error.
MarkLittell
I ended up rebuilding the OS on the systems to get past the issue.
Hopefully there is a better way, but I was running out of time.
