How do I run a Python script inside ArcMap to change datasources
5627
5
06-11-2018 04:32 AM
JoseSanchez
Hello everyone,
I need to run the python script below that changes layer datasources inside ArcMap when the mxd  is open.
How do I run the script with ArcMap Open?
import arcpy
from arcpy import env
from arcpy import mapping
newDataSource = r"Database Connections\NewSDEConnection.sde"
mapdoc = arcpy.mapping.MapDocument("CURRENT")
#mapdoc.findAndReplaceWorkspacePaths("<the directory you are changing from>" , newDataSource)
for df in mapping.ListDataFrames(mapdoc, "*"):
                    for lyr in mapping.ListLayers(mapdoc, "*", df):
                        try:
                            if lyr.supports("DATASOURCE"):
                                theData = lyr.dataSource
                                print "the Data " + theData
                                theWorkspacePath = lyr.workspacePath
                                print  theWorkspacePath
                                if theData.find(".ImageServer") == -1:
                                    if  ".sde" in theWorkspacePath.lower():
                                        mxd.findAndReplaceWorkspacePaths(theWorkspacePath,newDataSource,False)
                        except Exception as e:
                            print "The following error has occured:"
                            print e.message
                        except AttributeError:
                            pass
mapdoc.save()
del mapdoc
DanPatterson_Retired
Code Formatting the basics... to rule some apparent indentation errors.
Did you open the python window in arcmap and try to run it from there?
MichaelVolz
Esteemed Contributor
Are you doing this one mxd at a time?  If not, why not use ArcCatalog Set Data Sources tool?
JoseSanchez
Michael, it does not work with ArcCatalog Change Datasource because maps are using a Modling extension and when we tried to change the datasource in ArcMap it reset the model, and the user looses everything. So I am gdoing this one mxd at a time for some specific users.
Where is the Python window in ArcMap?  Can I load a python script?
Luke_Pinner
MVP Regular Contributor
You should be able to use `execfile('path/to/script.py')` to run your script from the python window in ArcMap.
