Query Widget: Time removed from Export
1183
06-08-2018 08:30 AM
ErickWiggs2
Howdy,
I'm using the online Web AppBuilder for ArcGIS to create a reporting dashboard. I set up the Query Widget to help the end user query my feature service and return results.
All of that is working fine, except that when I use the export to csv function it strips all of the times off of my date/time attributes.
I've checked the services I published, the webmap feeding the web app, and the database. All show correct date/ time in the attribute field. When I look at individual pop-ups, I see the date/ time; in both the web map and web app. When I look at the data in the Attribute Table within the dashboard - I see date/time, and when I export from the attribute table widget I see date time.
From what I can tell, the query widget doesn't support showing times from the queried feature service? Or am I missing something?
RobertScheitlin__GISP
Erick,
   There is no configuration that you are missing it is just a limitation of the current widget. You should contact esri tech support and file an enhancement request for this.
jchester73
Has this feature been added yet? It's important that the time stamp be included in exports in a full date and time format, not just from the main attribute table but from queries as well.
Not that I am aware of. Enhancement requests will gain more weight if you call it into esri tech support too.
