os.walk(arcpy.env.workspace) retur only files from the root folder
1602
5
06-07-2018 06:57 AM
JoseSanchez
Hello everyone,
How do I read only files from the root folder?
for (path, dirs, files) in os.walk(arcpy.env.workspace):
      for file in files:
            print file
JoshuaBixby
MVP Esteemed Contributor
JoseSanchez
just add a break
      for file in files:
            print file
# os.walk read only the root folder
   break
JonathanQuinn
Esri Notable Contributor
I'd use os.listdir:
>>> import os
>>> myFiles = os.listdir(r"C:\Users\jona6782\Documents\ArcGIS")
>>> print(myFiles)
['49058003.jpg', 'AddIns', 'c5A5E1C002DC8445A8FC05C471B1.json', 'Default.gdb', 'GeoNet', 'happy.png', 'JQNew - Copy.sd', 'JQNew.sd', 'LotsOfData.mxd', 'MyProject8.ppkx', 'MyService123.sd', 'New Folder', 'OnlineProjects', 'Packages', 'Portland.slpk', 'Projects', 'ProjectTemplates', 'ProPortalData', 'Rotterdam.slpk', 'scratch', 'scratch.gdb', 'Shapefiles', 'TilingSchemes', 'Toolbox.tbx', 'worldcities.gdb', 'WorldCities.mxd', 'WorldCitiesPG.mxd']
It will return a list of the files/folders in a specific directory.
JoshuaBixby
But with os.walk you know you are only getting files, with os.listdir you need to do additional steps to determine the type of file system object.
JonathanQuinn
Oops, missed the "only files" part. os.path.isfile can be used as well, then:
python - List files in ONLY the current directory - Stack Overflow
As always, lots of ways to do the same thing.
