Invalid json when loading layer
1611
06-07-2018 03:20 AM
TamasBeres
Here is how I try to load a FeatureLayer:
override fun onCreate(savedInstanceState: Bundle?) {
    super.onCreate(savedInstanceState)
    setContentView(R.layout.activity_main)
    // inflate MapView from layout
    mMapView = findViewById(R.id.mapview)
    val leftPoint = Point(16.374120968073157, 48.186396114084104, SpatialReferences.getWgs84())
    //bottom right
    val rightPoint = Point(16.38101960965946, 48.18357774813336, SpatialReferences.getWgs84())
    val initialExtent = Envelope(leftPoint, rightPoint)
    map = ArcGISMap(Basemap.createLightGrayCanvas())
    map.initialViewpoint = Viewpoint(initialExtent)
    val serviceFeatureTable = ServiceFeatureTable("https://services5.arcgis.com/jHdCsOKkBSDKvuhr/arcgis/rest/services/new_indoorschema_v8_inclHBF_WFL1/...")
    // create feature layer from service feature tables
    val featureLayer = FeatureLayer(serviceFeatureTable)
    featureLayer.addDoneLoadingListener {
        Log.d(TAG, "layer loading done. error:" + featureLayer.loadError)
    map.operationalLayers.add(featureLayer)
    // Pass a WebMap to the MapView constructor overload to display it.
    mapview.map = map
logcat I see:
layer loading done. error:com.esri.arcgisruntime.ArcGISRuntimeException: Invalid JSON
This layer works fine on the web. It fails on android. Why is that?
I've also tried to load it as a webmap, which fails with the exact same error message (9 out of 10 layers fail to load here: https://oebb.maps.arcgis.com/home/item.html?id=92626308405942d6a9251bb6e507cda6 )
Tags (1)
ChristopherVandrey
Hi Tamas
I'm having the same issue. The layer works perfectly on PC but wont display on Android or iOS?? Just checking to see if you found a fix.
Thanks!
