How to use User Defined Co-ordinate system?
1897
06-06-2018 05:03 AM
VijitWadhwa
My requirement is to have spaital reference with User Defined Coordinate System ?? I am from India , and the rquirement is to add projection system of Indian Grid System (IGRS) . I went through the documentation
Spatial references—ArcGIS Runtime SDK for .NET | ArcGIS for Developers , but I am unable to understand how to achieve it, Can anyone help me with some example or some kind of help ?? Thanks in advance
Vijit
MelitaKennedy
Esri Notable Contributor
If custom coordinate systems are supported at all, you would probably have to use it via a WKT (well-known text) string. Can you post the information for it:
geographic coordinate system / datum (+ ellipsoid)
map projection
parameters
linear units
Melita
VijitWadhwa
I have a .prj (projection file) , which contains well known text. Will it be sufficient?
dotMorten_esri
try
string wkt = File.ReadAllText(PATH_TO_PRJ_FILE);
SpatialReference sr = SpatialReference.Create(wkt);
