Open link in new window. Web App Builder GP Widget.
2012
06-04-2018 01:28 PM
deleted-user-uXtLD1BYscf0
I am using the WAP Developer Edition and have a geoprocessing widget (out of the box) widget that uses python and returns a hyperlink string as an output parameter.
example:
<p><a target="_blank" rel="noopener noreferrer" href="https://redirect.com"> Load into database </a></p>
The python creates this OK and the hyperlink works but the target="_blank" rel="noopener noreferrer" part of the string is ignored so it opens in the same window. I want it to always open in a new window. I confirmed this by using the "inspect" in my browser.
Is the WAB doing something to remove this functionality in the hyperlink? Do I need to dive into the javascript files in the widgets\Geoprocessing folder?? If so, where!?
RobertScheitlin__GISP
Peter,
   Yes the GP widget sanitizes the text using utils.sanitizeHTML(val); Which uses
https://code.google.com/p/google-caja/wiki/JsHtmlSanitizer
You can find this in the resultRendererManager.js
BilalSari1
I am also struggling with this problem. What would need to be changed in the resultRendererManager.js in order to fix this?
