Is there a way to conditionally make a field Read-Only?
1353
05-30-2018 02:57 PM
deleted-user-S67pw5ROhRKh
Is there a straight-forward way to conditionally make a field read-only in S123?
Otherwise, I will probably have to duplicate the field that I want to be conditionally read-only - one of which would and would-not be Read-Only, and it would be conditionally visible
Thanks!
IsmaelChivite
Esri Notable Contributor
Hi. As of version 2.8 it is not possible to write an expression in the read-only column. We are considering allowing expressions in the readonly and required columns in the future (potentially in the 3.0 release. July 2018).
SubbarajuGutti
I am using Survey123  Connect version : 3.10.
I am trying to add if expression in read only column.
 I am getting below error while converting into form.
Adding expressions  added in Read-only column in version 3.x as mentioned above ? Or am I doing any wrong here.
If not is there any way to read only survery123 form fields based on if condition.
SubbarajuGutti
After research, I am able to achieve this functionality by making following changes to Read only column.
Thank you.
