Replace empty cells with text in a text string
6446
10
05-31-2018 04:25 AM
TheodoreF
I can't find the answer anywhere, but how can I replace cells in a string field that have no data at all in them, with text? I'm not looking to replace spaces.
The second row here in Claim_Spend_in_£ (which is a text tield), has no data at all in it. It is not a blank space, or a NULL. I want all blank entries to be replaced with the text "Unrecorded". But the code I used above does nothing... I've tried using "", " ", None and neither of those work. I've also tried .strip to strip the field of any spaces first before running replace. No difference.
How can I acheive this?
And for further help, how can I replace all <Null> entries in a DATE formatted field, with the date "11/11/1111"? (Essentially I can't have any null values, so any unrecorded dates have to be a made up filler of 11/11/1111...
I see there is no .replace function for non-string fields...
DanPatterson_Retired
Try this... assuming it is some variant of a space or whitespace this field calculator expression should work
or it that fails you might try a variant
TheodoreF
The first solution gave ERROR 999999:
and the second solution did the same:
Thanks for the help though! I'm going to try selecting all blank entries and then insert "Unrecorded" into those selected.
EDIT: that won't work as I need this process to run outside of an ArcGIS Pro session. Select by attribute works off ToC layers...
You indented the return line.
Don't
see my example
TheodoreF
Ok interestingly my original code works with a few minor tweaks- swapping " " for ' '
hmmmm...
JoshuaBixby
MVP Esteemed Contributor
The single quote issue is likely related to SQL reference for query expressions used in ArcGIS—ArcGIS Pro | ArcGIS Desktop :
Common queries: Searching strings
Strings must always be enclosed in single quotation marks in queries, for example:
STATE_NAME = 'California'
As for the <null>, simply do a query for null to get them selected, then when you use the Field calculator, you just enter your value for the field calculation.  If it is an actual date field, I am not sure you just put in your 11/11/1111 string, but report back if you have an issue
JDM_82
This is what I needed to remember. Thank you!
'return' should use a single indent, you have double indented, hence it will fail
TheodoreF
Thanks Dan, both your solutions worked perfectly with the single indent. Interestingly when typing out your script it defautled to double indent when I hit Enter after the line ending "Unrecorded". I assumed Pro would handle indents for me.
