Right side of pop up window doesn't display
1272
05-25-2018 11:56 AM
ErikFernandez
Here's a screen shot. I've tried several monitors and have the same issue so I don't think it's a resolution issue. It happens with different windows, for some there's no functionality over on the right side so it's a non issue. With the legend properties window it is an issue though as I lose access to the up/down slider.  I just installed 10.6. Thanks in advance for any help!
Tags (1)
JoannLawler
Do you use greater than 100% for Windows settings: Display: Scale and Layout? I use 125% to improve the readability of my screen, and when I maximize a popup window (e.g., attribute table) it seems to size the window to the original screen resolution without taking into account the Windows Scale setting. I use a two-display setup that's extended, as well, and when I have the popup on the right-hand monitor it orients well to the right of the left hand edge. I hypothesize that it's orienting the top-left to (y-resolution + 1) but because I'm at 125% the y-resolution of the first monitor is 20% smaller.
ErikFernandez
Thanks Joann. I got a tip from someone to try the suggestions found here:
https://community.esri.com/thread/159484
https://support.esri.com/en/technical-article/000012739
I made several of the changes suggested on those pages, then rebooted. That fixed it. Not sure which change it was that fixed it, but it's fixed. The font size % may well have been part of it.
JudyStolen2
This worked for me -- thanks! I have the same setup you do.
