Function to grab the selection from another widget
5005
25
05-24-2018 10:32 AM
MartinOwens1
I've created a feature action in eSearch that can open another widget and send the selected featureSet, but I'm having trouble retrieving the selection from the other widget. I'm trying to use the selection from the eSearch wiget as an input for the results of another widget. Any help would be great!
RobertScheitlin__GISP
Martin,
   So you said that the fields in the eSearch result layer are the same as what is the _this.config.pdfReportFields have you actually verified this? Just because they are based on the same layer the eSearch result layer will not have a field if you did not configure that field to be visible in the results.
KenBuja
MVP Esteemed Contributor
You should move this over to the Web AppBuilder Custom Widgets‌ space for more exposure.
Martin,
   The eSearch creates a new FeatureLayer that is added to the map from the search results so all you have to do is grab that layer from the map like you would any other layer in the map from your other widget.
MartinOwens1
Thanks Robert, I'll have to try it that way. Out of curoisity on my onExecute code below line 12 send the feature set to my Reporting widget and the getFeatures function?
onExecute: function(featureSet){
      var def = new Deferred();
       WidgetManager.getInstance().triggerWidgetOpen('Reporting')
                 .then(function(Reporting) {
      var featuresA = featureSet.features[0];
      var selectionLayerResponse = featuresA;
      //console.log("SelectionLayer="+ selectionLayerResponse);
      var featAttr = featureSet.features[0].attributes;
      console.log(featAttr);
       var featGeom = featureSet.features[0].geometry;
      //console.log(featGeom);
      Reporting.getFeatures(featureSet.features);
      var fName = [];
      var widget;
      fName[1] = featureSet.displayFieldName;
      fName[2] = featureSet.geometryType;
      //console.log('log: '+fName[1] +' ' + fName[2]);
Martin,
  A feature set is just an array of graphics so get the layer and then use it’s graphics property.
MartinOwens1
Thanks for clarifying that for me. You said the eSearch creates a new FeatureLayer that is added to the map from the search results would you happen fo know the Id or name you are assigning it? It looks like "Search Results" is just the graphic because when I build the array using this.map.graphicsLayerIds it returns a result.
 array.forEach(this.map.layerIds, lang.hitch(this, function(layerId) {
          var layer = this.map.getLayer(layerId);
            if (layer.name === "Search Results"){
               addressPtsLayer = layer;
              console.log("This should return the Results" + addressPtsLayer);
Martin,
  A feature layer is also included in the GraphicsLayerIds since it extends from a GraphicsLayer.
So you loop through the GraphicsLayetIds to find the eSearch layer and then grab its graphics property
MartinOwens1
Thanks for the help Robert. I would expect the following code to be writing to the console but it's not doing anything. Can you take a look?
    getFeatures: function() {
       this.generateButtonDiv.style.display = 'none';
      this.generateReportTable.style.display = 'none';
      this.clearButtonDiv.style.display = 'block';
      this.messageNode.innerHTML = '';
       var self = this;
       array.forEach(this.map.graphicsLayerIds, lang.hitch(this, function(layerId) {
            console.log("This is a test" + addressPtsLayer);
         if (addressPtsLayer.graphics.length > 0) {
          self._zoomAndSelectFeatures(addressPtsLayer);
          self.reportFeatures = addressPtsLayer;
          self.messageNode.innerHTML = '';
          self.messageNode.appendChild(document.createTextNode('Number of selected features: ' + addressPtsLayer.graphics.length));
          self.generateButtonDiv.style.display = 'block';
          self.generateReportTable.style.display = 'block';
          self.clearButtonDiv.style.display = 'block';
          self.queryButtonDiv.style.display = 'none';
MartinOwens1
Nevermind that code is working. The issue I'm having is what happens after this function. I'm using
self.reportFeatures = addressPtsLayer; in a seperate function to generate a report but it's not getting the features for some reason. I'm going to have to look into it.
