Survey123 Inbox Subject View Query
1400
05-21-2018 01:54 PM
AlexP_
Please see two screenshots. I read documentation but I don't understand. It is confused. Screenshot 1 is coming from me. Inbox: I input Creator=${username}.but I also would like to add other fields as well just like screenshot 2. I want to view only specify fields such as case number field with creator=${username}. Does anyone know what is the correct query? Please advise. Thank you.
1)
2)
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
The label visible in the Inbox (as well as the other boxes) is set by the instance_name setting.  See Instance name—Survey123 for ArcGIS | ArcGIS for more information.
JamesTedrick
Hi Alex,
JosuaKoto
Hi I also have a similar problem but when I try to edit the sent surveys from the inbox it is blank.
