Can I use XPath or some other method to access fields?
393
05-17-2018 05:39 AM
roemhildtg
I'm trying to use a calculated value in a repeat, that would be set to a field value from the parent record. The issue is that the Parent field name is called ProjectGlobalID.
The child field name, in the repeat, is also called ProjectGlobalID. I tried setting the calculate to {ProjectGlobalID} which produces an error, so I also tried setting it to {../ProjectGlobalID} but that also throws an error.
This error also happens when trying to access a field that DateCreated that exists in both a Parent record and a child repeat record set. How can I reference DateCreated of the Parent instance for Instance_Name in this case?
Any tips on achieving this?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Gregg,
Currently, Survey123 cannot handle the .. identifier for parent node.
