PDF print error
757
05-14-2018 09:06 AM
deleted-user-Jhc6Dca2JfQr
Please help- I need to print six PDF maps- I have always changed the printer to "print to PDF" and it worked fine-
This morning it is not working- I have tried completely restarting the machine but still does not work.
Please see error below-
DanPatterson_Retired
Try printing a map that you know worked before.  If it works, then the difference lies in the properties you set for printing and/or the contents.  Things like fonts, image transparency and a load of other things have cause issues as you are probably aware from other posts on geonet.
Thanks Dan- I found a work around and used Windows printer to PDF- I was under a deadline to get it out.
As always appreciate the help!
