How to export Survey123 data using C#
2533
05-10-2018 08:45 AM
NicolasRoger
I have found that there exist some python script to export Survey123 data to your computer. Is there any similar code using the C# language with the ArcGIS Runtime SDK version 100.2.1?
I am trying to follow this link: Access the ArcGIS platform—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
But my application crash at the first line ( ArcGISPortal portal = await ArcGISPortal.CreateAsync(); )
Error code is the following:
"Une erreur s'est produite lors de l'envoi de la demande." System.Exception {System.Net.Http.HttpRequestException}
Any idea why?
EDIT: I found additionnal information about the error:
Proxy Authentication Required ( The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  )
EDIT: All problems solved. Here is the complete c# code to extract and delete the data (make sure you install and reference the arcgis Runtime .Net sdk and newtonSoft.JSON):
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Esri.ArcGISRuntime;
using Esri.ArcGISRuntime.Security;
using Esri.ArcGISRuntime.Portal;
using Esri.ArcGISRuntime.Data;
using System.Net.Http;
using System.Threading;
using System.IO;
using System.Net;
using System.Collections.Specialized;
using Newtonsoft.Json;
namespace xFormAGO
    public partial class Form1 : Form
        string nomUtilisateur = "yourusername";
        string motPass = "yourPassword";
        //Your service URL will be different but similar
        string ServiceUrl = @"https://services1.arcgis.com/xas33e1csd2dYTMBwrt4/ArcGIS/rest/services/service_832yf5aaa3a341fgucc03..."; //Layer 0
        string dossier = @"C:\test\";
        string fichier = "data.txt";
        public Form1()
            InitializeComponent();
            WebRequest.DefaultWebProxy.Credentials = CredentialCache.DefaultNetworkCredentials;
        //This button extract the data
        private async void cmdExtraction_Click(object sender, EventArgs e)
            try
                //Create ArcGIS Token
                var cred = await Esri.ArcGISRuntime.Security.AuthenticationManager.Current.GenerateCredentialAsync(
        new Uri("https://www.arcgis.com/sharing/rest"),
        nomUtilisateur,
        motPass) as ArcGISTokenCredential;
                //Build POST request
                string reponseStr;
                using (var wb = new WebClient())
                    //Request parameter. This one just download all data and Fields
                    var requete = new NameValueCollection();
                    requete["where"] = "1=1";
                    requete["f"] = "json";
                    requete["outFields"] = "*";
                    requete["token"] = cred.Token; //Important! Must be present
                    //Send request and wait for answer
                    var response = wb.UploadValues(ServiceUrl + "query", "POST", requete);
                    reponseStr = Encoding.UTF8.GetString(response); //Translate the answer to a JSON STRING
                File.WriteAllText(dossier + fichier, reponseStr); //Export the JSON string into a text file
                Rootobject dataResults = JsonConvert.DeserializeObject<Rootobject>(reponseStr); //Build the object containing the data. This line will crash for you here. Use google to understand how to convert a JSON string to a C# object. Or see the notes at the end of this code.
                //Use this object to manipulate your data as you wish
            catch (Exception exp)
                throw new Exception(exp.Message);
        //This button delete the data
        private async void cmdSupprimer_Click(object sender, EventArgs e)
                                                            nomUtilisateur,
            //POST request to delete data
                //This request deletes everything in the layer 0
                var data = new NameValueCollection();
                data["where"] = "1=1";
                data["f"] = "json";
                data["token"] = cred.Token;
                var response2 = wb.UploadValues(ServiceUrl + "deleteFeatures", "POST", data);
                string responseInString = Encoding.UTF8.GetString(response2);
                //Check the value of responseInString to see if deletion was successful
    //Here you will past the content of "data.txt" that you received earlier!!!
    //Very important
    //Using visual studio, you will do a special paste as follow:
    //-Open the data.txt file
    //-Copy all content
    //-Return back to visual studio and do a special "Paste as JSON format (Edition / special paste / paste JSON code as class)
    //You will then be able to use a similar line of code: Rootobject dataResults = JsonConvert.DeserializeObject<Rootobject>(reponseStr);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
NicolasRoger
Ok I found what was causing the error.
Here is how to solve it: Add this line at the beginning fo your code:
That's it! I am now able to connect to ArcGIS portals.
I should be able to figure out the rest.
NicolasRoger
NicolasRoger
using System;
using System.Data;
using System.Linq;
using System.Text;
using System.IO;
using System.Net;
namespace xFormAGO
        public Form1()
            try
        nomUtilisateur,
                string reponseStr;
                                                            nomUtilisateur,
                data["f"] = "json";
    //Very important
    //-Copy all content
I hope this help someone.
