AGOL multiple layers single relationship class
2368
05-09-2018 11:28 PM
JamesRead1
Just exploring Hosted Feature Layer relationship persistence in AGOL.
I have a FGDB PointFC, with a 1:M relationship class to a related table. I have:
PointFC
ABField (for def qry)
GlobalID (1) (DataType- GlobalD)
Relationship defined GlobalID to Point_FK
RelatedTable
Point_FK (M) (DataType - GUID)
GlobalID (DataType- GlobalD)
As guidance suggests..
In mxd (or aprx) I have a definition query set on ABField, to create two layers (pointing at the same source FC) which I thought should both 'honor' the relationship class.
On publishing as a hosted feature service to AGOL, and subsequently when using the edit widget to add a related table record:
GlobalID from the source FC is correctly propagated from layer 0 (A) to the related table
GlobalID from the source FC is not correctly propagated from layer 1 (B) to the related table
So my question is, is only a single layer (source) supported for relationship classes when publishing to AGOL? Will play with other options, but interested in views.
Happy to share the WebApp..
JamesRead1
Well, working around my own question, using another approach, If I bring the FC into AGOL as a single hosted feature layer, then duplicate the layer in the webmap, the relationships are honored correctly. Still interested to find out why only the first layer (0) (of multiple) published layers honors defined relationships though. Probably a logical explanation out there somewhere?
KellyGerrow
Esri Alum
Hi James,
This should work. Did you publish relationship classes with this data? If so, please get in touch with tech support to investigate further.
-Kelly
JamesRead1
Hi Kelly. Thanks for the response. Yes the relationship was published with the data (at least, it exists in the database). Pre-publication, the relationships work fine for the single data 'source' for all layers, in any desktop product. The fact that it is 'published' is demonstrated by the fact that it 'works' for layer 0. It's just the subsequent layers that don't honor the  relationship established in the FGDB, on publication to AGOL.
