Removing trailing character in a string
3796
05-08-2018 07:24 PM
BryanL
Hello All,
I would like to get some help on the following issue that I encountered in ArcGis 10.3
The objective is to look through the whole string and remove just the "." from the string
Object ID        Field
1                     Apple.
2                     Orange.
3                     Egg
4                     Pear
5                     Watermelon
I've tried using the following code which resulted in the all the last characters being removed instead of just "." :
Trim( LEFT ([Field], LEN( [Field]) -1))
I've also tried the code below which prompted an error message "Type mismatch" for both iif and InStr :
Trim(Left([Field], iif((InStr([Field], ".") = LEN([Field])), InStr([Field], ".")-1, LEN([Field]))))
I am using the Field Calculator in ArcGis 10.3.
Thanks for any help in advance.
RobertScheitlin__GISP
Bryan,
   You could use
Replace([Field], ".", "")
XanderBakker
Esri Esteemed Contributor
Use the Python parser and this:
!YourFieldName!.rstrip('.')
Bryan,
   You could use
BryanL
Thank you guys for the help. Appreciate it.
I 've since managed to get the result.
Cheers
