Publish Error code: 400
1441
05-08-2018 08:08 AM
CarlHolt1
Get the following error when publishing a new survey to ArcGIS Online for Connect v2.7.72
All the field names are lowercase, etc.
I was able to successfully publish a new survey April 2018.
Followed the solution suggested:
Hi.
try the following:
  1. In ArcGIS.com, login and go to 'My Contents'
  2. Look for the 'Survey-Daily_Vehicle_Checkout' folder and delete it
  3. In Connect, select the Survey Daily Vehicle Checkout so you  can preview it
  4. Click on the yellow button (looks like a folder) to open your Survey's directory in a File Explorer
  5. Next delete the Daily_Vehicle_Checkout.iteminfo file
  6. Back in Connect, try Publishing again
It looks like you may have deleted manually the Form and Feature Service from ArcGIS.com and left Connect and ArcGIS.com out of sync. Let me know if the above works for you.
JamesTedrick
Esri Esteemed Contributor
Hi Carl,
The words 'id' and 'comment' are key words in the database used by the hosted data store; can you rename both of them and try to republish (after deleting the folder Connect has made previously)?
CarlHolt1
typenamelabelhintconstraintconstraint_messagerequiredrequired_messageappearancedefaultreadonlyrelevantcalculationchoice_filterrepeat_countlabel::language1hint::language1media::audiomedia::imagebody::accuracyThresholdbind::esri:fieldTypebind::esri:fieldLengthbind::esri:fieldAliasbody::esri:inputMaskbind::esri:parametersbind::saveIncompletebind::type
begin groupinfoGeneral Information
dateinsp_dateInspection Dateyesnow()
textinsp_nameInspectoryesproperty('email')
select_one yes_noweatherWeatherrainfall over the previous 2-3 days?yeshorizontal
textgreenspace_nameGreenspace Name
textidGreenspace ID
textaddressGreenspace Address
integeracreageAcreage
geopointlocationLocationhide-input
imageoverview_photo1Overview Photoyes
imageoverview_photo2Overview Photostring-length(${overview_photo1})>0
imageoverview_photo3Overview Photostring-length(${overview_photo2})>0
end group
begin groupdebrisDebris Cleanout
select_one yes_nodrain_areaSite and contributing drainage areas clean of debris?yeshorizontal-compact
select_one yes_noyard_wasteDumping of yard waste into greenspace?yeshorizontal-compact
select_one yes_nolitterDumping of litteryeshorizontal-compact
imagedebris_photo1Debris Photo
imagedebris_photo2Debris Photostring-length(${debris_photo1})>0
imagedebris_photo3Debris Photostring-length(${debris_photo1})>0
textdebris_commCommentsmultiline
end group
begin groupvegetationVegetation
select_one yes_noerosionEvidence of erosion?yeshorizontal-compact
select_one yes_nosite_condIs site condition still according to regualtions?yeshorizontal-compact
textsite_cond_commIf no, provide details.multiline${site_cond}='no'
imageveg_photo1Vegetation Photo
imageveg_photo2Vegetation Photostring-length(${veg_photo1})>0
imageveg_photo3Vegetation Photostring-length(${veg_photo2})>0
textveg_commCommentsmultiline
end group
begin groupmaintenanceMaintenance
select_one yes_nograss_cutHas the grass been mowed?yeshorizontal-compact
select_one yes_nowaterEvidenc of standing water?yeshorizontal-compact
select_one yes_no_namulchMulch layer still in place?yeshorizontal-compact
imagemaintain_photo1Maintenance Photo
imagemaintain_photo2Maintenance Photostring-length(${maintain_photo1})>0
imagemaintain_photo3Maintenance Photostring-length(${maintain_photo2})>0
textmaintain_commCommentsmultiline
end group
begin groupsignSignage
select_one yes_nosite_signDoes site have signage?yeshorizontal-compact
select_one yes_nosign_condIs signage in good condition?yeshorizontal-compact
imagesign_photo1Sign Photo
imagesign_photo2Sign Photostring-length(${sign_photo1})>0
imagesign_photo3Sign Photostring-length(${sign_photo2})>0
end group
textcommentOverall Commentsmultiline
JamesTedrick
Hi Carl,
