oAuth ClientId Problem with ArcGIS Enterprise Portal
1539
05-04-2018 06:30 AM
PaulGiard
I am working on a prototype with the following design:
Portal authenticates using Microsoft Azure with Multifactor Authentication and everything works fine.  I can login and Authenticate with multifactor authentication.
I am now trying to connect to Portal via the ArcGIS Runtime .NET.  I am following the code found in the online samples for oAuth.
The issue I am having is the OAuthClientInfo.ClientId does not seem to exists in Portal.  When I do not supply a ClientId the challenge dialog does not display.  When I enter a random ClientId the challenge dialog displays with the message invalid ClientId
Where does the ClientId come from in Portal?
PaulGiard
Resolved.  By adding an application to the ArcGIS Enterprise Portal I have a ClientID to authenticate with.
PaulGiard
