Arcgis 10.5 - Single Output Map Algebra function
3349
05-04-2018 07:32 AM
VascoJesus
Dear all,
I was about to solve a problem of site location. I'm using raster data to define the best areas to locate my site.
I know arcgis has a function called Single Output Map Algebra, but i have the 10.5. Does anybody knows the function to do the same with arcgis 10.5?
Thanks in advance.
RS
ChrisDonohue__GISP
Back in earlier versions of ArcGIS Desktop there was Map Algebra.  For example:
ArcGIS Desktop Help 9.3 - Single Output Map Algebra
Nowadays, similar functionality in ArcGIS Desktop 10.x can be found in what is called Raster Calculator.
"The Raster Calculator tool allows you to create and execute a Map Algebra expression that will output a raster."
Raster Calculator—Help | ArcGIS for Desktop
https://community.esri.com/community/gis/analysis/spatial-analyst
Chris Donohue, GISP
ChrisDonohue__GISP
Chris Donohue, GISP
