I'm having difficulty understanding and implementing the queryTask at startup of a widget. That is, I need to perform a queryTask and based upon the result.features.length use that value in a conditional statement to continue to load/startup the rest of the way.
The problem is that queryTask.execute happens after the loading is completed and therefore my condition statement will never evaluate correctly. I know this because if you see where there are two console.log() statements, and print out in the console in this order:
First -- console.log("2 workplanCheck value is: ", this.workplanCheckValue)
Second -- console.log("1 workplanCheck value is: ", this.workplanCheckValue)
So this means that ALWAYS my this.workplanCheckValue variable doesn't get set in time before the conditional statement is evaluated!
constructor: function (args) {
lang.mixin(this, args);
window.map = this.map;
startup: function () {
if (this.workplanId) {
var queryUrl = "https://somesite/rest/services/myservice/FeatureServer/0";
var queryTask = new QueryTask(queryUrl);
var query = new Query();
query.returnGeometry = true;
query.outFields = ['*']
query.where = "workplanId ='" + this.workplanId + "'";
debugger;
queryTask.execute(query, lang.hitch(this, function (result) {
this.workplanCheckValue = result.features.length;
if (this.workplanCheckValue > 0 ) {
this.beginWork_Workplan_ExistingBoundary();
else if (this.workplanCheckValue < 1) {
this.beginWork_Workplan_NoExistingBoundary();
beginWork_Workplan_ExistingBoundary: function(){
beginWork_Workplan_NoExistingBoundary: function () {
