CELL STATISTICS with LIST RASTERS
3494
7
04-23-2018 03:07 AM
anTonialcaraz
I'm trying to run Mean annual cell statistics for groups of monthly rasters.
The output I'm getting is the same as the last raster in the list ("camp_t_srf_sep" in this example) so i assume the script is not actually iterating through all rasters.
Any help will be greatly appreciate it.
# Example of list of rasters:
 # camp_t_srf_apr
 # camp_t_srf_aug
 # camp_t_srf_dec
 # camp_t_srf_feb
 # camp_t_srf_jan
 # camp_t_srf_jul
 # camp_t_srf_jun
 # camp_t_srf_mar
 # camp_t_srf_may
 # camp_t_srf_nov
 # camp_t_srf_oct
 # camp_t_srf_sep
import arcpy
from arcpy import env
from arcpy.sa import *
env.overwriteOutput = True
env.extent = arcpy.Extent(-180.0, -90.0, 180.0, 90.0)
env.workspace = arcpy.GetParameterAsText(0)
StageAge = arcpy.GetParameterAsText(1)
rasterlist = arcpy.ListRasters(StageAge + "_*")
for raster in rasterlist:
    output_mean = CellStatistics(raster, "MEAN", "DATA")
    output_mean.save(env.workspace + "\\" + raster[:11] + "ann")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
You can use your for loop to build the list... just don't have cellstatistics in the loop
anTonialcaraz
just to add that I'm using 10.2.1 at the moment.
many thanks
Throw a print statement in... just to make sure you are getting the correct names, it will silently do nothing otherwise
And also.. Cell statistics expects a list/stack of rasters, not one at a time
http://desktop.arcgis.com/en/arcmap/latest/tools/spatial-analyst-toolbox/cell-statistics.htm
anTonialcaraz
Thank you Dan.
yes, the print statement gives me the list of rasters I want to calculate the mean from.
I thought I was giving the script the list of rasters with the variable rasterlist. I don't quite understand why it only processes the last raster in the list.
because you are cycling through each raster one at a time.
give it the whole list... examine the syntax in the code sample in the link I provided
anTonialcaraz
I know it works like as below. Just thought there would be a more elegant and economic way to put it using ListRasters
rasterlist5 = [StageAge + "_t_srf_apr", StageAge + "_t_srf_aug", StageAge + "_t_srf_dec", StageAge + "_t_srf_feb", StageAge + "_t_srf_jan", StageAge + "_t_srf_jul", StageAge + "_t_srf_jun", \
 StageAge + "_t_srf_mar", StageAge + "_t_srf_may", StageAge + "_t_srf_nov", StageAge + "_t_srf_oct", StageAge + "_t_srf_sep"]
output_mean = CellStatistics(rasterlist5, "MEAN", "DATA")
output_mean.save(OUTWorkspace + "\\" + raster[:11] + "ann")‍‍‍‍
anTonialcaraz
I see what you mean. Thanks so much Dan.
rasterlist5 = arcpy.ListRasters(StageAge + "_*")
for raster in rasterlist5:
    print raster
