Upload Shapefile
1301
04-23-2018 08:01 AM
JamesCrandall
I'm attempting to integrate THIS example into an existing widget I'm developing.  So far, I've added the "Choose File" dialog that allows for navigating to a directory
Pretty simple, just added this to my widget's html:
            <div class="jimu-btn" data-dojo-attach-event="click:toggleManualDrawTool">Manually Draw Boundary</div>
            <div class="jimu-btn finish-select" data-dojo-attach-event="click:onConfirmSelection">Add Selected Features to Boundary</div>
            <br /><br />
            <form enctype="multipart/form-data" method="post" id="uploadForm">
                <div class="field">
                    <label class="file-upload">
                        <span><strong>Upload a Shapefile</strong></span>
                        <input type="file" name="file" id="inFile" />
                    </label>
                </div>
            </form>
            <br /><br />
Now I'm trying to implement the actual process to get the upload processed into the graphics layer.  I'm running into an issue when attempting to hook this into the widget's js file.
So far I've just attempted to implement as in the example, by adding the various functions within my widget.js file and then adding this into my startup() function
startup: function () {
            on(dom.byId("uploadForm"), "change", function (event) {
                var fileName = event.target.value.toLowerCase();
                if (sniff("ie")) { //filename is full path in IE so extract the file name
                    var arr = fileName.split("\\");
                    fileName = arr[arr.length - 1];
                if (fileName.indexOf(".zip") !== -1) {//is file a zip - if not notify user
                    console.log("genFeatColl function fired")
                    this.generateFeatureCollection(fileName);
                else {
                    dom.byId('upload-status').innerHTML = '<p style="color:red">Add shapefile as .zip file</p>';
It hits the first log "genFeatColl function fired", however I'm getting this error on line 11 ("this.generateFeatureCollection")
Uncaught TypeError: this.generateFeatureCollection is not a function
    at HTMLFormElement.<anonymous>
Tags (1)
RobertScheitlin__GISP
James,
  The scope of this is not what you need because you are in another functions scope.
Use lang.hitch.
on(dom.byId("uploadForm"), "change", lang.hitch(this, function (event) {
James,
Use lang.hitch.
JamesCrandall
Thank you Robert.
