Geoprocessing.ExecuteToolAsync C# SYNTAX
4904
13
04-19-2018 09:50 AM
MikeRatcliffe
After reviewing available examples and references (only available in Python), I am unable to pass a successful Geoprocessing.MakeValueArray into the ExecuteToolAsync.  I am confident it is a C# #syntax issue, and need some help...
Example Code:
main_lyr.Select(qf, SelectionCombinationMethod.New);
var in_table = main_lyr;
var out_table = Path.Combine(Project.Current.DefaultGeodatabasePath, GVar.FtrLyr + " Results");
var statistics_fields = "FEET, Sum"; //[['FEET', 'SUM']]";
var case_field = "Diameter"; // "['Diameter']";
var args = Geoprocessing.MakeValueArray(in_table, out_table, statistics_fields, case_field);
var sp_ref = SpatialReferenceBuilder.CreateSpatialReference(102629); // NAD83 SP AL E FIPS 0101 Feet
var envi = Geoprocessing.MakeEnvironmentArray(outputCoordinateSystem: sp_ref);
Geoprocessing.ExecuteToolAsync("Statistics_analysis", args, envi, null, null, GPExecuteToolFlags.Default);
MikeRatcliffe
Firstly, THAT worked! "FEET Sum"
Just to clarify, the syntax documented here in the arcpy environment:
Summary Statistics—Help | ArcGIS Desktop
is
[["Shape_Area", "SUM"]]
Thank you.
BalajiVeera
Refer these two examples of ExecuteToolAsync method overloads from SDK document, either wait till complete the execution or execute with optional event handler
ArcGIS Pro 2.1 API Reference Guide
MikeRatcliffe
Thanks. I am aware of the SDK examples you reference above.  They do not help with my issue.  The issue is passing the correct syntax to the "Statistics_analysis" geoprocessing tool successfully from the example code above.  All of the ESRI tool references in ArcGIS Pro for "Statistics_analysis" have Python syntax.
NobbirAhmed
Esri Alum
As your sp_ref is an object you need to pass it through MakeValueArray(..). Could you please try with these changes:
var sp_ref = Geoprocessing.MakeValueArray(SpatialReferenceBuilder.CreateSpatialReference(102629));
If you follow the documentation you'll find which objects are supported directly.
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Geoprocessing#create-an-array-of-environment...
If you scroll down the above documentation you'll find this example:
// example of using ArcGIS.Core.Geometry.SpatialReference objectvar spatial_ref = await QueuedTask.Run(() => {     return SpatialReferenceBuilder.CreateSpatialReference(3857); });// call MakeValueArray on spatial_ref so that ExecuteToolAsync can internally use the objectvar sr_param = Geoprocessing.MakeValueArray(spatial_ref);
MikeRatcliffe
Thanks, Nobbir.
As before (passing sp_ref as an object), the process throws no exception, yet produces no output.  It just blocks the main application, then releases it after some time.
NobbirAhmed
Esri Alum
Have you used your code or the code in the sample? In the sample code (from the documentation link) a QueuedTask.Run(...) is used to created the spatial reference object.
MikeRatcliffe
all of the example code is contained in an await QueuedTask.Run(()=> {example code});
NobbirAhmed
Esri Alum
Just to be sure that issue is NOT caused by other parameter settings, I'm asking - have you called MakeValueArray on the spatial_ref object before passing it to MakeEnvironmentArray?
MikeRatcliffe
Yes, I am passing the spatial reference as an object to a value array to the environment.
present code:
var out_table = Path.Combine(Project.Current.DefaultGeodatabasePath, "Results");
var statistics_fields = "[[FEET], {Sum}]]";     *****syntax of these variables is assumed to be the failure*****
var case_field = "[Diameter]";                      ****this is the syntax provided by ESRI tool reference****
var sp_ref = Geoprocessing.MakeValueArray(SpatialReferenceBuilder.CreateSpatialReference(102629)); // NAD83 SP AL E FIPS 0101 Feet
NobbirAhmed
Esri Alum
Could you please try this way (without a comma between FEET and Sum so that it matches Python syntax)?
var statistics_fields = "FEET Sum";
