Multiple geopoint questions
3393
04-18-2018 11:48 AM
AldousTsang
The survey I am creating requires 3 geopoint questions (collecting Lat/Long) of Location of Incident, Beginning point and Ending point of Discharge. I know you can use a repeat for multiple geopoint of the same question. What would be the recommended approach for this issue? A clunky way is wording the question, "Geolocate: Incident/Beginning/Ending point" and have a text entry to describe each geopoint. Can you use conditions and relevant inside the repeat group? Also, originally requested to have select one choices of N/A, Same as Location of Incident, add Geopoint for beginning and ending points, which is easy to do with multiple geopoints. Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Aldous,
As you say, this could be done via repeat, with a dropdown to designate which point is which.  Another alternative would be to have 3 geopoint questions in the form with no repeats, setting the last 2 geopoint questions to null and recording the lat/long of points via pulldata functions - see The Power of Nothing for an example with 2 points.
JamesTedrick
Hi Aldous,
AldousTsang
Thanks James, I'll try the later since I already have the geopoints created.
