ArcGIS Online parsing of google map location url
3503
04-17-2018 09:42 AM
PeteVitt
Hi - I've got a hyperlink to google map location I've inserted into ArcGIS online pop-up -- the problem is ArcGIS online isnt parsing the url correctly.  the url is:
https://www.google.com/maps/place/34%C2%B004'42.1%22N+117%C2%B042'17.6%22W/@34.078349,-117.7070777,1...
when I I click the link in ArcGIS on line it goes to a place in the northern part of Algeria
it should be going to this location as it correctly does in ArcMap:
I've tried adding the anchor tag with target blank:
<a target='blank' href='https://www.google.com/maps/place/34%C2%B004'42.1%22N+117%C2%B042'17.6%22W/@34.078349,-117.7070777,1...'>More Info</a>
but it gives the same result.  Any idea how I could change the llink to get it to parse correctly?  I'm thinking it has to be one of the special characters -- % or something that is throwing it off
In ArcGIS pro it throws an error without the anchor tag, and goes to the wrong location with the anchor tag
Pete
by Anonymous User
Not applicable
Actually I just tried bitly and it didn't seem to work but you can get a shortened link by clicking the share button in Google Maps.
(view in My Videos)
by Anonymous User
Not applicable
Did you try using a shortened URL like you generate using bitly.com?
by Anonymous User
Not applicable
(view in My Videos)
PeteVitt
Thanks - that did the trick!
KellyGerrow
Esri Alum
Hi Pete,
The quote by the 04 was truncating the href url early. Ti avoid this issue, try using double quotes if a single quote is contained in the url. Using the shortened link will remove the need to do this.
Also, if you want to try a similar workflow with ArcGIS Online Maps, check out the marker functionality in this documentation:
Use URL parameters to modify embedded maps—ArcGIS Online Help | ArcGIS
-Kelly
