Utility network feature service error
3684
04-16-2018 09:50 PM
AbhijeetKulkarni
Hi All,
I have managed to publish the utility network service using ArcGIS Pro but when I look in Arcgis Server Manager, service is in stopped state. When I attempt to start it, I get attached error.(error.jpg). I do have utility network extension license active. (license.jpg). Did I miss some config somewhere?
Error:
Service failed to start
<servicename>.MapServer:
<server domain name>
Could not obtain a license for Utility Networks.
Edit:
I could find below WARNING message in 'SharingJobLog'. I hope this will be useful for UN developers to locate point of failure.
WARNING 002504: The service configuration was created, but it failed to start.
Database: Oracle 12c
Thank You.
AbhijeetKulkarni
This issue occurs when ArcGIS Server license is 'standard'.
ESRI has verified this bug as BUG-000113567 - Unable to start the Utility Network Service on ArcGIS Server with a Standard license.
AbhijeetKulkarni
AbhijeetKulkarni
Thor Morten Kopaas has credit for reporting this to ESRI tech support and getting BUG assigned. Thanks to Thor.
