Javacript 3.23 bug with momentjs package?
3248
6
04-16-2018 08:36 AM
EricO_Neal1
I'm attempting to use a 3rd party library in a WAB custom widget, and there is a dependency for momentjs.  Moment seems to be packaged with the ESRI Javascript API, but has a different definition for 'main' in init.js than the other packages (notice the .js on the end of it):
main: "OnDemandGrid",
main: "Store",
main: "moment.js",
When the define line is executed in the 3rd party library, it fails with:
GET https://js.arcgis.com/3.21/moment/moment.js.js net::ERR_ABORTED
It seems that the extra .js on moment in init.js is crapping things out and I notice that this has changed in JS API version 4.6.
BalajiVeera
Remove .js for moment in init.js
main: "moment",
EricO_Neal1
I get that, but will need to download and host the JS API myself.  Cant fix it on the CDN.
ReneRubalcava
Esri Frequent Contributor
You should be able to override the dojoConfig for your WAB widget by with something like this
window.dojoConfig = {
  packages: [
      location: "https://js.arcgis.com/3.<version>/moment/moment",
      main: "moment",
Add the version of the API that the version of WAB using. You might need to check for an existing dojoConfig and make sure you don't override some current dojoConfig settings.
We'll get this fixed in 3.25
EricO_Neal1
I made the change that you siggested in both my Widget.js and my application's init.js and it now fails with:
GET https://js.arcgis.com/3.21/moment/main.js net::ERR_ABORTED
Not sure what main.js is or why its asking for it now.  I'm going to host  the API with my app and hack up it's init.js for now while developing.  I noticed that once the WAB application get built, the proper moment code seems to get updated (from WAB init.js):
if (window.apiUrl.substr(window.apiUrl.length - 'arcgis-js-api/'.length,
'arcgis-js-api/'.length) === 'arcgis-js-api/') {
//after build, we put js api here
//user can also download release api package and put here
dojoConfig.baseUrl = window.path;
Eric
ReneRubalcava
Correction, fixed in 3.24
EricO_Neal1
Nice!
