I have ten raster files to work on their pixel depth is 32 bit and one of them is 2 bit. I need to mosaic them but they are not doable as all of them are not in the same pixel size. How can I change it?
- Thank you!
- Thank you!
Set the extent and cell size and you can use Resample http://pro.arcgis.com/en/pro-app/tool-reference/data-management/resample.htm
When running the tool, ensure that you check the Environments to ensure everything is as you need
You can use Copy Raster—Help | ArcGIS for Desktop
