LayerToKML issue: null vectors from a loop
574
04-13-2018 06:50 AM
DavidePavia1
Hy everyone,
I'm working on a python script that loops the LayerToKML tool on a set of layers; here's the problem: the first execution works fine, all the others (hundreds) creates .kmz files like the one below...
...the whole set of geometries are invisible and placed at Equator or North Pole; on the contrary, all the attributes are correct.
I'm running the script with an IDE (PyScripter, 32 Bit, python 2.7.2): if I run the same code within the ArcGIS (10.1) python window, it works perfectly!!
Any idea would be really appreciated, thanks in advance.
Davide
DavidePavia1
Hy everyone, we've solved the problem by changing the system decimal separator, from comma to point. Thanks for the attention and have a good day.
