ActiveMapViewChangedEvent
2259
04-12-2018 08:20 AM
BrianBulla
Honored Contributor
I'm trying to detect when the current MapView changes, so I can then activate/deactivate a button on a toolbar based on layers in the active map.
But when I click on (for example) the 'Catalog' tab, the ActiveMapViewChangedEvent fires and I get a NullReferenceException.  As a workaround, I just catch the exception and disable the tool.
Is there a better way to determine if the user is no longer on a 'MapView' tab??
            ActiveMapViewChangedEvent.Subscribe((args) =>
                try
                    var lyr = MapView.Active.Map.FindLayers("SDEDB1.GISADMIN.ADDR_Durham").FirstOrDefault();
                    if (lyr == null)
                        FrameworkApplication.State.Deactivate(StateID);
                    else
                        FrameworkApplication.State.Activate(StateID);
                catch (NullReferenceException)
UmaHarano
Hi Brian
When the ActiveMapViewChanged event fires, you can check the Event args to see if the "IncomingView" arg is null.
Like this code snippet:
ActiveMapViewChangedEvent.Subscribe(OnActiveMapViewChanged);
private async void OnActiveMapViewChanged
            (ActiveMapViewChangedEventArgs activeMapViewChangedEventArgs)
      if (activeMapViewChangedEventArgs.IncomingView == null) return;
NarelleChedzey
Brian,
In addition you should never assume that there is always a mapview active.  What if your user has a layout active?   What if your user has no mapviews open.   In both of these scenarios, MapView.Active will be null  and MapView.Active.Map will throw a nullReferenceException as you are experiencing.
Rather than wrap in a try, catch.  you should add the following to your code
if (MapView.Active == null) return;
BrianBulla
Honored Contributor
Great....thanks Uma and Narelle for your help.  Both methods work as I need them to.
