Problem with Related Charts Widget and a Date field for the Label Field
1446
04-12-2018 10:56 AM
deleted-user-XenGTCuuDnDD
It seems with the recent update to ArcGIS Online the Related Charts Widget is not working when a Date field is used as the Label Field.  Previously, I had this widget working in many Web Apps with the Label Field  using a Date field and it sorted and displayed the Date value correctly.  All of a sudden this has stopped working for me in the recent AGOL update. Now, the widget just spins the loading image forever...
If I use other field types as the Label Field, the widget works OK.
Is anyone else experiencing this and maybe have a solution?
Thanks in advance!
AllisonMuise1
Michael Brown‌ Could you please open a support incident with this issue so that we can troubleshoot and address it ASAP?
I am not able to reproduce the issue, but an analyst can work with you to identify what's going on.
Just got a support incident opened, case number: 02098999
