Issues with calculating data with Survey123
501
04-11-2018 06:08 PM
LauraWeinstein-Berman
I am having trouble calculating pull data on a .csv file that I have connected through Survey123. I have a file that contains folio numbers, addresses, building years, and zoning from tax parcel data. The .csv has been put into the media folder of my survey. I believe my calculation formula is correct. When I go into the survey, the information doesn't populate or return any value. This will increase efficiency in the field and is critical for project success. If you can help, can you please send me a private message in order to view sensitive files. Thank you, Laura.
BrandonArmstrong
Hi Laura,
I sent you a private message in GeoNet with my email address.  Please send over your XLSForm and CSV when you have a chance.
Brandon
