Pulldata() on public survey doesn't return values
1477
04-09-2018 03:20 PM
AyeletGreenberg
I created a simple survey and used the pulldata() function to return values of room size.
It works well on the app and returns the values for the room size from the csv file, but it doesn't work in a browser. Instead it displays the string "NaN" (regardless if I'm signed in or not).
The survey is set as public, and everyone can submit their answers.
https://survey123.arcgis.com/share/c2b9944090194f38bc326d6f54c23247
How can I fix that?
Tags (1)
JohnathanHasthorpe
Hi Ayelet
The issue is that you are using a + to concatenate your string:
      ${RoomSize} +  " Sq ft"
The webform requires that you use concat(), so please try the following:
      concat(${RoomSize}, " Sq ft")
Cheers
John
JohnathanHasthorpe
Hi Ayelet
Cheers
John
IsmaelChivite
Esri Notable Contributor
AyeletGreenberg
Thanks. canadianclimate it works now.
I have another question about this form.
When the Room Number is 'Other' I don't want the (relevant) Room Size to appear because it has no values.
Because all the room numbers are 4 digits long I used this formula:
string-length(${RoomNumber})>0 and string-length(${RoomNumber})<5
What would be the right way to do this when the string length vary?
