Input location using to Network Analyst and Finding the route
1123
04-09-2018 02:40 AM
JohnMcConalogue
I have a shapefile of locations and have another shapefile with one location which is a Start Point.
I want to input the name of one of the locations and then Network Analyst will return the best route to the location from the Start Point.
Anyone know how this can be achieved using python?
Tags (1)
RachelApplebaum
You'll need to geocode the address to get the location in a feature layer/table (which can be in memory) then pass that feature layer/table into Add Locations (Add Locations—Help | ArcGIS Desktop ).
Of course for the geocoding, you'll need a geocoder or a geocoding service. If you have your own, you can use that, or you could also use Google or several other options. See the options in Geocode only one address in arcpy.  or Geocode Addresses—Help | ArcGIS Desktop or arcgis desktop - How to geocode a single address in Python Script/ ModelBuilder? - Geographic Inform...  for ideas.
NeilAyres
Doing this in python is actually quite complicated (imho).
Some tips here, see example 4
Make Route Layer—Help | ArcGIS Desktop
JohnMcConalogue
Thanks for the reply Neil.
I am trying to get the user to add the address and then Network analyst will fine the route.
Here is the code prompting the user to input the address:
if len(address) == 0: address = raw_input("Which address do you wish to examine? ") QueryString = "Address_Name = \'" + address.title() + "\'"
Any idea how to pass the "address" parameter to the python script to be used by Network analyst?
RachelApplebaum
