Widget to show webmap description info?
537
04-06-2018 06:15 AM
Arpa_PiemonteGeoportal_Team
The question is very simple bu t we didn't find yet ann answer:
we use our Web App Builder applicaton to load different webmaps passing their webmap iD in URL parameters.
i.e.
https://webgis.arpa.piemonte.it/Geoviewer2D/index.html?webmap=eb115c5a889842bda744c72ad3d28cb9
is there a widget that could  show dyinamically the AGOL webmap description text for the webmap that is loaded ?
It seems that the different widgets that we tested (about, spalshscreen etc) can only show static text defined at config level
Thank you
Tags (1)
RobertBorchert
Honored Contributor
Not dynamically but if your editing your Web App it will show you which Web Map it drawing from
