Errors Running GP Models With Python Script
1649
04-04-2018 08:06 AM
JoshSaad2
I'm getting an error whenever I try to run a python script outside of ArcGIS Pro that executes geoprocessing tools that I made.  The purpose of the tools is to ETL data from outside databases into my GIS database.  I created python scripts using arcpy.ImportToolbox to run these tools so that I can schedule them to run overnight automatically, based on this article.  The individual commands all ran fine using the Python window in ArcGIS Pro, but I keep getting the error in the attached screenshot.
Python Error
I ensured that I'm using the correct Python shell , 3.6.4, located in the ArcGIS Pro folder.  I was thinking that the problem may be because my model pulls data from other database connections, but I'm not sure. If anyone can help me with this  I would greatly appreciate it.
BruceHarold
Esri Frequent Contributor
Josh does this use Data Interoperability extension?  If so you'll need to check out the extension in your script.
JoshSaad2
I'm not using Data Interoperability, just feature to feature, append, dissolve, calculate field, and delete rows.  Thanks though.
GaryBarden
I just ran into this problem. Were you ever able to find a solution?
