How to delete the empty dataset from gdb
2375
03-31-2018 03:38 AM
santhoshp
Hi Dear,
Attached gdb here.How to delete the empty dataset from gdb in this gdb data available in HVAC, Fire alarm, Audiovisual, Fire Protection dataset rest of datasets empty for information any python code available plz help.
Santhosh
2 Solutions
XanderBakker
Esri Esteemed Contributor
To show you how you can delete empty featureclasses, feature datasets and tables, see the code below:
def main():
    import arcpy
    import os
    fgdb = r'C:\GeoNet\DeleteEmpty\SSUC_FGDB_V3.gdb'
    # list feature datasets
    arcpy.env.workspace = fgdb
    fdss = arcpy.ListDatasets()
    fdss.append('')
    # loop through feature datasets to delete empty ones
    print("Delete empty featureclasses")
    for fds in fdss:
        print("Processing FDS: {}".format(fds))
        fcs = arcpy.ListFeatureClasses('*', None, fds)
        # loop through featureclasses in feature dataset
        for fc_name in fcs:
            fc = os.path.join(fgdb, fds, fc_name)
            count = GetCount(fc)
            if count == 0:
                # if fc is empty, delete it
                print(" - Deleting: {}".format(fc_name))
                arcpy.Delete_management(fc)
            else:
                print(" - Skip: {}".format(fc_name))
    # delete empty feature datasets
    print("Delete empty feature datasets")
    for fds in fdss:
        if len(fcs) == 0:
            print(" - Delete FDS {}".format(fds))
            arcpy.Delete_management(fds)
        else:
            print(" - Keep FDS {}".format(fds))
    # delete empty tables
    print("Delete empty tables")
    tbls = arcpy.ListTables()
    for tbl_name in tbls:
        tbl = os.path.join(fgdb, tbl_name)
        count = GetCount(tbl)
        if count == 0:
            # if tbl is empty, delete it
            print(" - Deleting: {}".format(tbl_name))
            arcpy.Delete_management(tbl)
        else:
            print(" - Skip: {}".format(tbl_name))
def GetCount(fc):
    return int(arcpy.GetCount_management(fc).getOutput(0))
if __name__ == '__main__':
    main()
XanderBakker
You're welcome, I'm glad it worked.
DanPatterson_Retired
Not sure what you mean by wanting 'arcpy'.
Through arcpy, you implement the code snippet to match your case using Delete_management
XanderBakker
def main():
    import arcpy
    import os
    fdss.append('')
    for fds in fdss:
        for fc_name in fcs:
            if count == 0:
            else:
    for fds in fdss:
        if len(fcs) == 0:
        else:
        if count == 0:
        else:
def GetCount(fc):
    main()
santhoshp
Xander Bakker ,
Thank you So much .
Santhosh
XanderBakker
