ListInput problem in WAB
1873
7
03-30-2018 04:01 AM
MatejSkerjanc
Hello
i've assembled a crude test Dojo JSFiddle Template - JSFiddle  of list input. This works flawlessly in jsfiddle but in WAB custom widget the input reports errors.
Has anyone used this cool dojo widget ListInput successfully in WAB developers edition? Or did anyone else get this issue and solved it?
Thank you for the help in advance
Best regards,
Matej
Adri2cPérez_Beneito
Hi!
You can visit my GitHub. I just added an example.
Cheers!
Adri2cPérez_Beneito
Hi!
Cheers!
MatejSkerjanc
Hello mrs Adri2c
havent had the chance to test since i've used multi select instead for the moment, but what makes your example tick?
the define line 'xstyle/css!https://dojotoolkit.org/scripts/dojo/dojox/form/resources/ListInput.css' ?
MatejSkerjanc
I tried basic sample from your example
new ListInput({
value: "Hello!, it's Dojox!, :)"
}, this.listNode);
and i get a.destroy is not a function
Adri2cPérez_Beneito
Hi!
Dojox Input List needs this css style. Here getting it using http.
Hm, are you using 'data-dojo-attach-point' instead of 'id' in your html file? Also be careful with the order of imports.
Cheers
MatejSkerjanc
i used both ways attach point and regular div. Both provide same result - same error as mentioned above
MatejSkerjanc
Pastiebin.com 5ac321f83c11c
this is the part of the code
MatejSkerjanc
god...i noticed the issue at least the general vicinity of issue. I've extended array with distinct i guess it doesnt like it. I'll check what's going on. Thanks for the sample i marked it as solved and valid!
// if (!Array.prototype.distinct) {
// Array.prototype.distinct = function () {
// function onlyUnique(value, index, self) {
// return self.indexOf(value) === index;
// if (Array.prototype.filter) {
// return this.filter(onlyUnique);
// else {
// var o = {}, a = [], i, e;
// for (i = 0; e = this; i++) { o = 1 };
// for (e in o) { a.push(e) };
// return a;
