Calculate fields
3532
15
03-29-2018 10:59 AM
jaykapalczynski
Honored Contributor
I am trying to concatenate a couple XY values
I have the X and Y fields (Double data type)
I created a Test field (string)
CONCAT(X, Y)
Then simply tried to calculate a simple test field
NAME  - this is a field name
I get this error:
ERROR002536 Table Jurisdictions does not support or is in a state to support SQL Expressions
Any thoughts?  Can do this in ArcMap in 2 seconds...ArcPro....ugggggg
JoeBorgione
Don't have an answer for you; how do you use CONCAT(X,Y) in ArcMap?  I get the same error as you  in ArcGIS Pro using the SQL parser choice, but if fails in ArcMap for me. I've never used CONCAT(X,Y) before and had to google it just to find out what it is.
I got this simple Python def() to work in Pro:
DanPatterson_Retired
python parser
X and Y , two fields
x = 10
y = 20
"{} {}".format(x, y)
'10 20'‍‍‍‍‍‍
you would therefore use !YourField! for each of the x and y values.
String concatenation in python, or check out arcade. but vb stuff is the new cobol
jaykapalczynski
Honored Contributor
That's guys....both do the trick....have to pick one for the answer....I like Dan's simpler approach but both answers are greatly appreciated....Still confused why simply SQL statements are not working in the SQL Expression Type
Somethin such as the below is failing
FieldName =
'TestingValue'
FieldName=
"TestingValue"
KoryKramer
Esri Community Moderator
You said that you get
That's the error in Pro?  Can you send a screenshot?  What database are you working with (file, Oracle, SQL server, etc.?) and version?
jaykapalczynski
Honored Contributor
This is ArcGIS Pro 2.1.2
I am simply hitting a shapefile - I havent tried on a GDB or SDE FC
python3
jaykapalczynski
Honored Contributor
my example was the most simplistic I could think of...why does it fail with SQL Expression, which is the main question in this thread...
I was able to get it working in Python3
shapefiles (yours) and geodatabase tables (mine) apparently don't support unless you 'do' something.
Maybe yours and mine is obviously not an sql thing.  I never use sql, I had erroneously assumed that yours was a valid sql thing.
Which... according to the help are
apparently....
