ArcGIS REST API Server Query - Which URL should I use Query(GET) or Query (POST)
2575
03-29-2018 11:45 AM
deleted-user-4LjGx0CueIPn
I am writing a simple test application using Left-let. The feature class is coming directly from the server which works great, but when I create a query the new URL does not return any records. In other words, my application does not show any of the points in the feature class. Since I am not an expert of the field, I started to think if I was choosing the wrong URL but both Query(GET) and Query (POST) give me the same result.
I have done the following:
Change "Return Geometry : True"
any help would be great.
JohnGravois
if you want to return all the features in the service, you need to supply a SQL where clause that always resolves to true.
where: 1=1
http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1=1&f=html
John,
I was under the impression that by running the query using Query(GET) or Query (POST) I would get the correct link. I type the query directly and that seems to work now. I appreciate your help.
