Unable adding or using costume Toolbox after upgrading to 10.5.1
1100
03-30-2018 03:14 AM
GalAvraham
Hi All
Recently I've upgraded ArcGIS Desktop on my machine - removing the 10.4.1 version, restarting the machine and installing the 10.5.1 version.
I then opened my of mxd saved under 10.4 - all went well. When tried adding a toolbox created in previous version (containing several models as well as script tools, organized in 3 different tool sets), it won't added to the toolboxes pan in ArcMap. When tried accessing the toolbox through ArcCatalog , the toolbox seems empty.
I then tried loading the toolbox into a total new mxd file saved with the newly installed version - again with no success.
I appreciate any help on this, thanks in advance
Gal Avraham
DanPatterson_Retired
Where were the scripts saved associated with the toolboxes?
There is a chance that they were removed when you removed 10.4.  Have you checked your recycle bin?
GalAvraham
Hi Dan
Thanks for your reply.
The scripts were saved to a none default location - they are stored, and available on my c:\ drive. The tools referencing these scripts are not available under that toolbox, as well as the tool sets.
As I mentioned:
1. I can't add the toolbox to the toolbox pan in ArcMap.
2. There were also other models in that toolbox - none of them available. The toolbox seems to be empty when accessed through ArcCatalog.
Gal
I suspect the tools will have to be rebuilt.  I don't use models so I don't know how they are handled in toolboxes
GalAvraham
Thanks.
I ended up restoring a backup of this toolbox - I manage to reconstruct most of them while others were in a continuous authoring process.
Thanks again,
Gal
