Using multiple pulldata functions in a calculate field
1606
5
03-29-2018 03:18 PM
JohnMarra
I can't seem to get the calculation to work correctly when I use multiple pulldata functions. For example.
3 * pulldata('tubing', 'vol', 'dia', ${field_7}) * ${field_19})
works fine, but
3 * pulldata('tubing', 'vol', 'dia', ${field_7}) * ${field_19}) + pulldata('flow', 'vol', 'size', ${field_21}
does not work. It gives me no answer at all.
EDIT: As a workaround, I can assign the 2nd pulldata function to a decimal field and use the decimal field in the place of the 2nd pull data function. I just don't want to have to see the decimal field in the survey.
SMauri
I will try something like this...
typenamecalculation
calculationquestion1pulldata('tubing', 'vol', 'dia', ${field_7})
calculationquestion2pulldata('flow', 'vol', 'size', ${field_21}
calculationquestion33 * ${question1} * ${field_19}) + ${question2}
Cheers
Stefano
SMauri
typenamecalculation
Cheers
Stefano
JohnMarra
Got it. That makes sense. Thank you.
SMauri
Risultati immagini per ok
...and don't forget to mark question as solved
JohnMarra
This solution no longer works in version 2.7.72???
What is up with this update?
JamesTedrick
Esri Esteemed Contributor
Hi John,
I do not believe that the issue you are experiencing is 2.7 specific.  The XLSform translator (the software that translates the XLS file to the form XML file), does not recognize pulldata functions when they do not begin a line - the procedure you mentioned (dedicating a line to receive a pulldata value, then using it in a calculation) is the preferred form authoring pattern.
